Tsp prc 2.5 LS6 head flow rate?
Old Nov 24, 2016 | 03:13 PM
blackfbird98's Avatar
Default Tsp prc 2.5 LS6 head flow rate?
Hey guys so I have a set of prc 2.5 ls6 heads from tsp that were milled.20 over for my tsp v3 cam, does anyone one know the flow rate on these heads? I'm trying to figure out what the compression rate will be on a stock lq4 block I picked up. Any info is appreciated
Old Nov 25, 2016 | 01:51 PM
Anyone?
Old Nov 25, 2016 | 05:28 PM
omc8's Avatar
Here you go.......... The flow data below shows the superior performance of the PRC stage 2.5 LS6 cylinder heads!
Flow Data: 3.910" Flow Plate - No Exhaust Pipe
Lift Intake Flow Exhaust Flow
.200" 147 cfm 114 cfm
.300" 209 cfm 152 cfm
.400" 258 cfm 191 cfm
.500" 294 cfm 207 cfm
.600" 316 cfm 226 cfm
Old Nov 25, 2016 | 08:50 PM
BrntWS6's Avatar
I have that setup and its 10.6:1 on stock ls1 block. Dont know if that would change with your block or not.
Old Nov 26, 2016 | 03:57 PM
Any idea on the chamber cc on these heads?
Old Nov 27, 2016 | 09:56 AM
BrntWS6's Avatar
58-64cc
Old Nov 30, 2016 | 03:40 PM
Aaron at SDPC's Avatar
Should be a number engraved in the rocker area. Find that hand engraved number and give them a call. They will be able to look up exactly how those cylinder heads left the building.
