Coolant Temp Guage reading Low
Old Nov 28, 2016 | 08:20 AM
Genhero's Avatar
Default Coolant Temp Guage reading Low
When I swapped the engine I noticed the sensor was damage. I ordered a new one with the correct 3 prong sensor for a 98.
If I use a scanner the ECU is correctly reading 210 but the guage cluster shows at the 1/4 mark (195).
If I pull the back of the gauge cluster off it looks like I can just twist the part that controls the temp gauge out. Should I just replace that piece or is there something else I might be missing?
