FAST 90mm Intake Questions
I also like the rough factory-like look so I just hit it with some Krylon Fusion satin black and a white paint pen for the letters. Every now and then I scratch it and I can just hit that spot with another spray and it blends in once dry.
I know a lot of guys on this site go in depth with adhesion promoters, primer, etc but I haven't found it necessary. Guess it depends on what color/look you are going for. Other colors probably wouldn't be as easy to touch up as the satin black.
You might be able to clean it well enough without taking it apart though in which case you wouldn't risk damaging the rope seal. Not sure if they are still available or not.
