MIL codes P0171 & P0174, tried everything and need help
Old Dec 6, 2016 | 11:32 AM
Endrance's Avatar
Default MIL codes P0171 & P0174, tried everything and need help
So as stated in the title my car is throwing these 2 codes and is running very lean. It's even more apparent when I want to get on the throttle and at about 2500rpm I can feel the car die down a bit. My old maf went bad so I just had it replaced, but it continues to throw the code. I was running catless for about 4 years or so and recently had a hi flow catted system put on my car since I moved to a state with inspections. The bank 1 sensor 1 O2 sensor has also been replaced. I had it at a local dealer and they said another problem could be a potential vacuum leak, but they couldn't find one. My bank 1 sensor 2 O2 is now throwing a code as well, could the O2 issue be the cause? I also had the injectors cleaned to no avail and according to my gauge I'm at the proper psi. Any help is GREATLY appreciated.
Thanks in advance,
Endrance
Old Dec 6, 2016 | 11:57 AM
Old Geezer's Avatar
There's a diagnostic/tune forum for such questions...
Old Dec 6, 2016 | 01:01 PM
Endrance's Avatar
Didn't see the specific location for these types of questions but thanks for your insight and help...
