Run a fast 90 or an ls6? Help me choose!
LS6 to Fast will behave similar just not as drastic since the LS6 intake is better than the LS1 right off the bat.
The Fast stuff needs a lot of messaging in the running air flow/throttle follower tables to get the driveability dialed in. The throttle response is very sensitive on the Fast too.
The LS6 works fine for 90% of the heads cam LS1's, but for those wanting to extract that last bit of power, Fast will definitely make more ponies.
But I'd go with a FAST over an LS6 if you already have it. You can always run your stock TB with an adapter until you can get the car into the hands of a tuner.
With that said, Steve is a really good tuner. He may already have a baseline file for the FAST that will help a lot. I now have a couple of a good baselines for the 102 and could probably load a close enough tune for someone without much issue.
