Do I need the battery sensor?
Old Jan 8, 2017 | 08:32 AM
field57's Avatar
Default Do I need the battery sensor?
I had my harness reworked (2005 truck) and I'm starting to put everything together in the swap car. I have the battery sensor plug that is supposed to go over the negative cable. Do I need it? Problem is my battery is on the opposite side as the plug so I don't want to run a cable across the engine compartment if I don't have to, thanks.
Old Jan 8, 2017 | 01:12 PM
garys 68's Avatar
No, check out LT1swap for instructions on how to bypass it.
I kept mine but without the BCM it defaults to something like 13.5 V.
Old Jan 8, 2017 | 01:50 PM
field57's Avatar
Awesome thanks!
