EXhaust help
Old Jan 16, 2017 | 10:38 AM
pozesd99''s Avatar
Default EXhaust help
I have a single 4in i pipe dumped currently right before the diff. Im thinking about making it over the axle and the dumped. Similar to the mufflex system. Can anyone guide me in the correct angles and bends to buy to make this possible?
Current set up:
What i want minus that muffler just piping:
Old Jan 16, 2017 | 12:33 PM
pozesd99''s Avatar
Diy exhaust guys! Need your help!
Old Jan 16, 2017 | 01:55 PM
Full-Force's Avatar
look at a catback and you can answer this yourself. Just be aware you will have to cut and weld to get custom angles. You cant just buy some bends and expect it to all line up. If I was going to do it I would probably get three 90* bends.
Hawk's has the system you are looking for already made up. Its not cheap but it will fit and save a headache. No offense but if you have to ask what bends to buy then its probably not a project you want to take on....
Here is the Hawk's kit ---> http://www.hawksmotorsports.com/hawk...aust-system-4/
Old Jan 16, 2017 | 02:24 PM
pozesd99''s Avatar
All I am doing is buying the material and having an exhaust shop do the rest
Old Jan 16, 2017 | 03:09 PM
zachm89's Avatar
Pretty sure youre going to need the upper panhard bar relocation to get the 4" pipe up and over the rear end without hitting anything just like you would if you were doing over the axles duals. I have a full Hawks 4" kit in the box at the house, I can take some closer pictures of all of the bends if youd like.
Old Jan 16, 2017 | 04:10 PM
Full-Force's Avatar
