MSD Coil Harness
Old Jan 18, 2017 | 11:32 PM
Trucker82's Avatar
Default MSD Coil Harness
Has anyone held a MSD coil Harness in there hand? Does it look like it has beefier wires? Is it worth the extra coin over stock GM LS2 harnesses?
Thanks!
Old Jan 19, 2017 | 08:22 AM
farmington's Avatar
the harness and the coils are not an improvement over the factory parts. save your money
Old Jan 19, 2017 | 08:42 AM
pantera_efi's Avatar
Default PVC vs TXL "crosslink"
Hi, you have a correct observation.
The MSD PVC insulated wire is thicker due to LOWER dielectric strength.
The PVC will MELT at lower temperature than OEM GM wire.
MY "sub-harness" IS an upgrade, we use Crosslink insulation wire with a TXL size.
I found this necessary due to Under Hood Temperatures of BAJA race cars.
Lance
