Battery relocation with pics!
Nothing wrong with the build, looks clean. Just if weight reduction/weight transfer is your goal there are other options out there.
The Braile 3121 is gel battery but it still produces gasses and therefore it needs to be in a sealed box and vented to the outside since the 4th gen's have an open trunk and no rear firewall. Also the box needs mounted to the frame rail with 3/8" or larger?
You can use these to cover up the holes, all purchased on ebay:-Dorman 45470
-12 Locking Rigid Plastic Hole Plugs - To Fit 3/16" Opening - Black Nylon
The fender liner push pins can be replaced with:
http://www.eastcoastbolts.com/1997-O...ners15pcs.aspx
Starts up no problem.
Used #4 gauge wire and grounding clamps to tie it in
JEGS Performance Products 10341K - switch $48
Taylor 48200 box 11.25" x 9.5" x 8.75" $95
Braile 3121 6.6 x 5.2 x 6.8 $230
100 Amp Circuit Breaker $18
Uxcell 4.7" x 4.7" x 2.3 junction box $10
0/1 and 2 awg ring terminals $20
ANL fuse holder and fuse $10
Probably cut the box down in size or have one custom made. If I follow this diagram below, I would think 20ft of 2awg ($40) and 15ft of 1/0 ($40) would be plenty enough of wire.
