ASP pulley???
Old Jun 24, 2004 | 01:21 PM
Nick D's Avatar
Default ASP pulley???
Which one to get, underdrive, overdrive, alternator and crank, can someone please enlighten me?
Old Jun 24, 2004 | 01:24 PM
killer01ws6's Avatar
Unless you have a monster stereo just the underdrive crank pulley will get you all you need.
if you do have that stereo them get the overdrive alt, but other wise no need.
Old Jun 24, 2004 | 01:34 PM
haole_boySS's Avatar
you can get an underdrive for the crank and an overdrive for the alternator.
Old Jun 24, 2004 | 07:29 PM
White Fire'99's Avatar
is the overdrive alt pully bigger or smaller than the stock one?
Old Jun 24, 2004 | 08:28 PM
chpmnsws6's Avatar
smaller. makes it spin faster and make more juice for your thump in the trunk pleasure
Old Jun 25, 2004 | 04:30 PM
Bad30th's Avatar
Also, the ASP pulley makes a full 13v charge at 900 RPM - if you have a raised idle you may not need the alternator pulley even if you have a decent sized stereo.
My idle is at 950 warm, 1050 cold and I haven't had any charging problems at all with my ASP pulley.
Bad30th
