power steering pump pulley install
this is as tight as i can make it but i read somewhere that the center bolt is supposed to be flush with the pulley..
looks like its pressed on as far as it will go. the tool is only like $20 to rent or $20 to buy. i just bought one, figured i might use it again.
a little trick I did was to put the belt on as I was pressing my new billet pulley on.. that way you can see if the belt is aligned with the other pulleys as you go.
