Help
Old Jun 26, 2004 | 08:22 AM
bees99TA's Avatar
Default Help
i AM TRYING TO LEARN TO DO WORK ON MY CAR MYSELF. ANYWAY I LEFT A SENSOR WIRE DISCONNECTED FROM THE AIR BOX LID AND NOW THE SERVICE ENGINE LIGHT IS ON. I PLUGGED IT BACK IN AND TRIED TO START AND RE-SART THE CAR A FEW TIMES TO RESET THE COMPUTER....wILL THAT RESET IT OR DO i NEED TO DRIVE IT A COUPLE OF TIMES...ALSO I DID JUST CUT THE BOTTOM OF THE AIR BOX TO MAKE THE HOLES LARGER. WOULD THAT HAVE ANYTHING TO DO WITH THE LIGHT GOING OFF. tHE CUT WAS UNDER THE AIR FILTER SO I WOULDN'T THINK THAT WAS THE PROBLEM.
Old Jun 26, 2004 | 09:18 AM
Kevin 276's Avatar
No, restarting won't help reset the light. Use the link it gives you lots of useful info for the future. And who told you to drill holes under the air box?
http://www.ls1howto.com/
Old Jun 26, 2004 | 09:35 AM
bees99TA's Avatar
www.installuniversity.com
I did the Free Ram AIr from this website....They answered my question....
Reminder:
Make sure you have the keys out of the ignition. Why? When you remove the sensors from the air box lid assembly you do not want to start the car. You will set the Service Engine Soon (SES) light. If you do start the car without placing the sensors back in you can easily reset the SES light by following these steps:
1. Turn key to the "on" position but don't start car
2. Pull the PCM BAT and PCM IGN fuses in engine compartment
3. Wait approximately 5 minutes
4. Turn ignition off
5. Replace fuses
6. Start the car and then make sure the light has gone off
I just need to know which fuses are which now
Old Jun 26, 2004 | 09:37 AM
bees99TA's Avatar
Sorry for the waste of time....reading the manual helps
