2002 FBody LS6 Intake Question
Old Apr 20, 2017 | 07:55 PM
Luckyzach's Avatar
Default 2002 FBody LS6 Intake Question
I was wondering something about my engine, I am led to believe that my 2002 Pontiac Trans Am has an LS6 Intake. I know this is true by the visual inspection of it. With that being said, I am curious as to whether or not my engine also has the LS6 Valley Cover or if it has the LS1 valley cover? I'm losing oil slowly and trying to pin point the location. I would assume with my car having an LS6 Intake that it would have an LS6 Valley Cover but I don't want to remove the Intake to find out if at all possible. If I am posting in the wrong place, I apologize. Just wanted to get some knowledge to avoid the hassle of changing out something that I didn't have to.
Old Apr 20, 2017 | 08:46 PM
wannafbody's Avatar
The LS6 valley cover should have the pcv line coming out of the passenger front of the engine.
Old Apr 20, 2017 | 10:20 PM
Luckyzach's Avatar
I just checked it and I don't have the LS6 Valley Cover. Thank you.
Old Apr 22, 2017 | 11:54 AM
z-maro's Avatar
No F-bodies came with the LS6 valley, however being a 2002 there is about a 25% chance you have a LS6 block. You can check the block number and if so you can switch to the LS6 valley without having to cut the block.
