No fuel at schrader valve
Bought a new regulator..no change.
Any insight? Anyone else had this problem I've searched but came up with nothing.
Even my Dec 97 trans am had no fpr.
So you're not suppose to have a regulator like a vette does
Is your fpr connect to an engine vacuum line?
https://ls1tech.com/forums/fueling-i...regulator.html
Vette rail with fpr
The only pump I would use in my 98 is the race tronix. The 98 pumps and hangers are very delicate
Fbody pressure regulator (to note the pump below is a 99+ which is collapseable. The 98 hanger assembly bends and twists into the tank)
