need help with Fast TB
Old May 27, 2017 | 06:31 PM
ls3swap's Avatar
Default need help with Fast TB
I have a aftermarket throttle body but it doe not have the ball or what ever to hook the trans cable end to. Can I purchase one does anybody know what its called and where I can get one. My friend has the exact same Fast tb and has manual valve body tranny and says I can have his pin. thing is how do you remove it or can it be taken off and put on another tb. thanks
Old May 29, 2017 | 09:43 PM
slogo's Avatar
If you Have the 700 trans, you need to google, TV cable for 700 trans to ls1,
that will get you started, it is very important you adjust that cable correct or your trans
will give up on you very quick, keep searching there is someone on here that has done it
and has some pictures.
Most people will tell you to just use a newer trans, to save the hassle, but most people think if there is not a youtube video on how to solve it, it's not worth trying, or that trans is not worth the trouble, they can be built just as good as any of them. Good Luck.
