Stock Diameter Aftermarket Balancer
Old Jun 18, 2017 | 04:16 PM
snakeeyes's Avatar
Default Stock Diameter Aftermarket Balancer
Is there any other performance brand out there that makes the stock diameter balancer for the truck pulley spacing besides ATI?
Almost everything I see available is 25% underdrive or 10-15% overdrive. Seems weird with as many truck blocks being swapped that there is a lack of options for the truck pulleys spacing.
If I went with a 25% underdrive, I have to replace some pulleys for alternator and powersteering correct?
Old Jun 18, 2017 | 04:42 PM
98CayenneT/A's Avatar
Not a stock pulley but a nice setup here. It also comes with a alt. pulley https://m.summitracing.com/parts/sum-c2520 You don't necessarily need the extra pulley's unless you are having charging issues.
I went with the summit 25% pulley for my Ls1 and it's a very nice pulley. No alternator pulley and I have zero charging issues.
Old Jun 18, 2017 | 04:49 PM
snakeeyes's Avatar
Yeah been thinking about that one from summit. Seems to be the same manufacture as the trick flow damper which is just a black painted version. Was kinda worried about charging and having to start changing all the pulleys just for a damper.
Might give the ASP camaro pulley a try its 15% under pulley. Also, looking at the Romac pulley that texas speed sells.
