Grease for bolts?
Old Jun 19, 2017 | 11:03 AM
lowchevytrucks8503's Avatar
Default Grease for bolts?
I was wondering what grease is safe for putting in water pump bolts. I am replacing the water pump on an aluminum block ls1 and the original bolts were a little seized up. I'm not sure if the bolts I'm putting in are steel or aluminum. I am using 3/4" spacers from ICT billet with an LS3 water pump.
Old Jun 19, 2017 | 11:17 AM
98CayenneT/A's Avatar
Anti seize or even bearing grease will work just fine.
Old Jun 19, 2017 | 11:31 AM
thanks! Just wanted to make sure I didnt use anything that I shouldn't
