Potentially silly TPS sensor question.
When they are equal, the report to the EMS will be EQUAL.
Lance
Do you know if there is any cause or likely chance that voltage will be different with different manufacturers of TPS sensors? AC Delco doesnt make one and the company that manufactures the one I am looking at on Advance is BWD.
AC Delco IS an aftermarket line.
Borg Warner is an aftermarket line.
Both could be imprinted with the CTS "logo".
The art of a "copy" is possible though it would be very hard for a TSP sensor to be manufactured with an incorrect calibration.
NOW WHAT IS EASY is for you to "install" the sensor with incorrect method.
Measure your Closed Throttle Voltage.
Measure your Wide Open Throttle Voltage.
ADJUST the sensor position IF required, "slot" the mounting holes IF necessary.
Lance"
