Air conditioning lost?
Old Jun 28, 2004 | 11:17 PM
RW99's Avatar
Question Air conditioning lost?
Post heads/cam install, the AC stopped working. No visible crimped/bent lines, and a recharge of the system holds pressure. When commanded by a scan tool to turn on, the compressor runs and the AC functions correctly, nice and cool.
So what's the next step? Most likely culprit(s)? Any way that LS1edit tuning might have messed up the PCM somehow to provoke this problem?
Thanks in advance for any ideas.
Rich
Old Jun 28, 2004 | 11:25 PM
2xLS1's Avatar
There is a %TPS to enable and disable the compressor in edit. It is something you could look at.
Old Jun 29, 2004 | 06:12 AM
robertbartsch's Avatar
We need a separate topic on the Board to cover AC issues!
Old Jun 29, 2004 | 06:27 AM
770Guy's Avatar
And a Power steering section too damnit.
Old Jun 29, 2004 | 11:20 AM
RW99's Avatar
2xLS1, thanks for the info... what are the normal %TPS values for enable/disable?
Old Jun 29, 2004 | 12:01 PM
2xLS1's Avatar
On my stock 99 A4 file it is:
%TPS to Disable - 100
%TPS to ReEnable - 0
RPM to Disable - 3950
RPM to Re Enable - 0
