Removing driver's side cylinder head, advice please
1. If I have the machine shop clean up the heads to make sure the valves are seating properly, what should I make sure to tell them?
2. Is there a problem with having the machine shop clean up/re-check one head and not the other?
3. Are lifters, lifter trays, or pushrods necessary to replace if they all look fine?
4. Is this a good time to do something else like a delete, conversion, or relocation other than the LS6 PCV conversion while I've got the intake off? What else should I do while I'm in there?
5. Any other tips/advice when doing this?
The car is mostly stock. 2000 LS1 with 853 heads, SLP Lid/ram-air, LTH, ORY, EGR/AIR delete.
