fuel pump relay not receiving power to open
blue pin 2 is 'trans range "b" in' ? im a manual transmission if that means anything (this goes to the 'automatic transmission fluid pressure manual valve position switch' ... unless i'm mistaken what blue pin 2 is?
The following users liked this post:
01whtMaro (06-14-2020)
#34
I was reading back over the first few posts. When I said "ground side of the relay" what I actually meant was "is the relay grounded?" By using that jumper wire you aren't actually testing to see if the ground to the relay is good.
#35
I'm not sure how i'm not testing the ground if i use that jumper wire ... where would the ground be located if it's not there?
#36
One is 12v from the fuel pump fuse.
One goes to the fuel pump.
One is the 5v signal from the pcm.
One is ground.
When the relay is installed, it won't function without a good ground.
Jumping the fused 12v to the fuel pump does nothing to test the relay's ground feed.
#37
The 4 pins were your relay plugs into.
One is ground.
One is ground.
#39
I may be mistaken but is that circuit only powered up for 2 seconds when the ignition is first turned on and then once the pcm receives a cranking reference it powers it up for as long as the pcm sees the cranking reference?
#40
