Cable or Electronic Throttle Body?
Old Aug 8, 2017 | 06:53 AM
RedRascal's Avatar
Default Cable or Electronic Throttle Body?
I have started my first LS engine build for my project truck using a 5.3L LC9 truck engine as the donor. I like that setup because I like the layout of the accessory brackets and it fits the project truck nicely. My question is thus: Given that I have the flexibility at this point to choose, what kind of Throttle Body (TB) should I use, a cable actuated TB or electronic TB? I tend to lean old school and be inclined to go with a cable actuated TB; however, there might be some advantages with going with the electronic unit.
Old Aug 18, 2017 | 04:45 PM
JOHNNY59's Avatar
Keep it simple and go with the cable TB.
Old Aug 19, 2017 | 10:19 AM
99 Black Bird T/A's Avatar
Cable TB is simple and what my 91RS has however if you go with a big 102mm TB on a Fast LSXR or LSXRT later the cable set up is harder to tune for driveability based on what I've been told. The electronic TB with supporting electronic pedal, PCM etc is more flexible for driveability tuning in some cases.
Ultimately it's what do you want out of the set up. If a big 100mm+ TB is in the future electronic TB is ideally better otherwise cable TB.
Old Aug 19, 2017 | 10:49 AM
Plus it's easier to hook up a set of wires than routing a throttle cable and lining it up correctly.
