P0351!!!!
Old Aug 16, 2017 | 06:51 PM
ETNFUEL's Avatar
Default P0351!!!!
So got the car back from the tuner the other day and it started throwing a P0351. Ignition coil "A" primary and secondary malfunction (cylinder 1 coil). so I swapped a coil from my buddies car. and it threw the code after a couple mins. I cleaned the back driver side ground for the coils and made sure that the bolt was tight. cleared the code and it came back on. swapped spark plug wires from the passenger side bank code still came on. Any suggestions only thing I haven't done is change the plug and check voltage reference.
Old Aug 18, 2017 | 02:57 PM
joecar's Avatar
Check that the pins in coil's connector/plug are ok (making contact and not deformed).
P0351
Old Aug 18, 2017 | 03:11 PM
JoeNova's Avatar
Restricted User
Some tuners will use a small probe and shove it in the coil connector to pick up an RPM signal for the dyno. Like above, make sure something didn't get screwed up with the actual connector.
