Cleaning the intake
Old Aug 24, 2017 | 09:57 PM
birdblack's Avatar
Default Cleaning the intake
I just recently put on a Mightymouse oil catch can. Now that I don't have that oil going thru the intake what is the best way to clean the inside of the intake?
Old Aug 24, 2017 | 10:10 PM
I know there is a thread about this somewhere on this forum. Which section is a good guess. But it's here somewhere. Do a search.
Old Aug 25, 2017 | 02:04 AM
sjsingle1's Avatar
I dont know of anyway to clean it with the intake on the engine.....off the engine.....tub full of purple power or simple green does the trick
Old Aug 25, 2017 | 06:48 AM
Old Geezer's Avatar
Old Aug 25, 2017 | 07:17 AM
ss4chad's Avatar
Take the TB off and spray carb cleaner in the intake. Unplug the fuel & ignition relay and turn the motor over as your spraying it. After a full can of cleaner is sprayed in it, let the starter rest for about 10 minutes then turn it over again and let the heavy liquid get sucked out. Then reconnect the relays and fire it up, might have a little white smoke for a split second but then should be good.
Chad
Old Aug 29, 2017 | 01:38 PM
MikeZ28TA's Avatar
I put in tub of Purple Power overnight and cleaned it real nice. Of course, take everything off of it first.
