Anyone replace muffler in stock catback?
What type of muffler does the SLP Dual/Dual come with? Would that hook-up to the stock tubing without major headaches?
This could be because I had stock tips with 2.5 inch pipe after the muffler. You can see my dyno #'s at my webpage below for exact #'s. Hope this helps.
I think with 3inch pipe after the muffler may have netted me a little more power
but I just recieved my Hooker catback and will put it in with dyno results later. This magnaflow is a few months old if you want it. I would take 50 bucks for it.
Good luck, sounds like a nice car you have there!
Derek
PM me for info on Muffler, I don't want to hijack the thread!
thanks,
Derek
Derek
A guy i know gained 60 HP by opening his cutout on his 429 (i think) LT1. He had a flowmaster muffler and stock piping. The cutout was after his y-pipe with longtubes.
The stock over the axle part looks a little more restrictive than the Hooker over the axle piece(as well as other aftermarket pieces). I think that there has to be some reason the aftermarket pipes are 3in. campared to 2.5 in. I have seen people dyno only 4 to 5 hp more with a cutout from a good flowing exhaust such as Hooker. That is why I posted my info.
Before my cam, I dynoed only 292 HP and 298 Tq with a bullet in the I pipe with a lid. Only picked up a few horsepower over the stock muffler.
Derek
Sounds pretty good to me.
I used a short bullet and dumped my stock muffler. The bullet is 3" id and flows like open pipe. Helped me a bunch.
Anyway, .25" larger pipe is hardly a reason to spend mega bux for a whole cat-back. The stock muffler is the restriction.
As for tail pipes and tips, larger pipes after the muffler, or big tips, are meaningless... Think about it, the exhaust goes through a single pipe that is around 3", you could have two 2" tailpipes and still flow the same as the one 3" I-pipe. Going any larger is cosmetic. Not to mention that exhaust gasses shrink as they go back through the exhaust. That means you could go with progressively smaller pipe and still flow the same out back as up front.
I have just a bullet and lid, on the dyno with other F-cars, I pulled the same/more power than cars with a full cat-back and lid.
I also saw guys with conventional mufflers and lid keep right up...
Except Blowmasters
, they are nearly as restrictive as stock.Dave
Dave
