Jegs oil pan capacity question
Old Sep 1, 2017 | 10:14 PM
Cwarta's Avatar
Default Jegs oil pan capacity question
So, I was running the hummer Pan before on my swap. I changed to the jegs pan with remote oil filter location, I retained the dipstick from the hummer pan. In order to get to the same location on the dipstick as before, I have to put in 8-9 quarts of oil. Now, in my mind that shouldn't hurt anything because the oil level should be the same as factory in the pan, sonit shouldn't cause windage issues etc, right?
Old Sep 1, 2017 | 10:42 PM
As long as the pickup is close to the bottom, and as you say, no windage problems, should be good to go! And if you even suspect any windage hassles, you could drop a quart or two without any guilt feelings.
Old Sep 2, 2017 | 12:55 AM
tug686spd's Avatar
Not sure I agree. I can see an extra quart but not 2-3. The baffling in the pan is designed to hold down a certain amount of oil. Adding that much extra I'm sure it will allow quite a bit of oil to climb the back of block on hard launches or pulls.
