Typhoon intake fuel rails question
Old Sep 4, 2017 | 09:29 AM
VandykeT/A's Avatar
Default Typhoon intake fuel rails question
I ended up with a PP Typhoon without rails. Will any aftermarket fuel rail work as long as the center is flexible or do I need the actual PP fuel rails. Its the 85mm version going on a C5.
Old Sep 4, 2017 | 12:10 PM
wannafbody's Avatar
I've heard that people have had issues with the Typhoon rails leaking. I'd think that the BBK rails would fit.
Old Sep 5, 2017 | 08:29 AM
Lsnewbee's Avatar
Im running the pp rails with no problems or leaks. I have been rumming them for 3 years now with the 96 intake if you get them you may have to shorten the crossover line thats what i had to do it would either hit the hood if you put it in the front or the cowl on the rear
