Installed the Jet Hot LTs and ORY
Old Jun 30, 2004 | 10:20 AM
RobzwickidSS's Avatar
Default Installed the Jet Hot LTs and ORY
Well I got everything in. I will say that the quality of the Jet Hots was very good, no slag or shitty welds. The Y pipe looks good and fits well.(I still have a bang on the floor board, nothing a motor mount wont fix) I did pick up some GM replacement metal gaskets instead of using the paper ones in the kit. I only wish they would have put 1 more stepped band clamp and 2 regular band clamps instead of the U-bolt clamps. Ground clearance has not shown to be a problem yet. I have the BMR boxed sfc and they sit lower then the collectors or the Y pipe. The sound through the Borla is nice, it sounds a little better when I use the block off plate though. All I can say is make sure you pull the steering shaft, starter, and all spark plugs.
