Crank/cam sensor wires burnt.
Old Sep 6, 2017 | 07:55 PM
NZLS1's Avatar
Default Crank/cam sensor wires burnt.
Hi All
The new headers for my LS1 are very close to the wires for Cranks/cam sensor by starter motor and look damaged/burnt from old headers. Can i cut and lengthen the wires to reroute away from the heat. I am pretty good with a soldering iron but will the added resistance cause problems.
Thanks
Old Sep 6, 2017 | 10:15 PM
They can be lengthened. Just be sure to make good connections, but I think you know that already.
Old Sep 6, 2017 | 10:49 PM
NZLS1's Avatar
thanks
Old Sep 6, 2017 | 11:38 PM
No sweat, man. Hope it all works out!
Old Sep 7, 2017 | 05:26 AM
wph351's Avatar
You are fine. Test the connection when Complete. Try to keep it under 1.5 ohm.
