injector upgrade????
Old Sep 20, 2017 | 11:25 AM
hokeplaya05's Avatar
Default injector upgrade????
Hi guys, so I am putting the final touches on the lq4 I have been putting together to swap into my truck and am wondering if I need to upgrade injectors and if so what size would you recommend? motor is a 2001 370ci lq4, stock crank with forged rods and pistons, custom cam from Martin Smallwood (can get specs if needed), untouched 243 heads, and factory truck intake. I am thinking it will be around 400fwhp and probably around that if not more torque judging from setups I've seen similar to mine so I am assuming I will need to upgrade the injectors. Thanks
Old Sep 20, 2017 | 11:59 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
What intake and wiring harness?
Old Sep 20, 2017 | 12:10 PM
using the factory truck intake. I am going to be re-pinning the factory 5.7 vortec harness to work with the lq4, so using the factory lq4 injector harness.
Old Sep 20, 2017 | 12:12 PM
Id look for some flex fuel injectors or 8.1l. Those should set you up and not be so pricey plus youd have the factory info/offsets to plug right in.
Old Sep 26, 2017 | 11:11 AM
thanks, I will look into those
Old Sep 27, 2017 | 08:27 AM
01ssreda4's Avatar
Anything from FIC
