Grinding ignition coil?
Old Sep 29, 2017 | 11:55 PM
HappySalesman's Avatar
Default Grinding ignition coil?
Hey all
So I'm doing a coil relocation in my fbody, and to make a long story short, the U-shaped part of the coil is hitting the bolts holding my relocation brackets in, and I need to clearance them. I know the u-shaped part is magnetic... does anyone know if these are critical to coil function or are they just a bracket? If I grind a little bit off, think they would be negatively affected?
Old Sep 30, 2017 | 01:13 AM
98CayenneT/A's Avatar
You can grind/ cut on them with no ill effects.
I cut mine so the circle where the bolt goes is now a U.
I will post a picture in the morning.
Old Sep 30, 2017 | 02:05 AM
Perfect! Thanks for the response
Old Oct 1, 2017 | 08:56 AM
Want me to post a picture or ya good ?
