Why 6.0s are so thirsty?
With my Camaro on an open trailer I can only get 10-11 MPG though. This thing needs more power or 4.10's to pull the way I think it should. I will probably get rid of it in a couple of years and get a NNBS truck with a 5.3/6L80E, or find one with a 6.2L in it. Both would pull better than my 1500HD
Or, if I can afford to do so, I will look into getting a 14+ Silverado, Ecoboost, or a Ram with the 8-speed.
In OD it's in the 22-2300 range at 70-75. In 3rd it's up near 3,000 RPM at the same speeds. Just depends on if I can leave it in OD or not. With the boat it obviously struggles in OD but with the car on an open trailer it will pull in OD no problem. I don't let it downshift to 2nd unless it's an absolutely huge hill and it drops below 60 mph which doesn't happen much at all.
Blindly comparing mpgs wont help either.
Ive seen 2 sep trucks with vin numbers 11 off from each other, one was +11 on long term fuel trims the other was -5 or so.
Replace those pos patiunum plugs, clean the fuel injectors, get a good air filter and make sure the O2s give a proper wave form and operate right. Also sea foam it with the right stuff (they make an actual intake cleaning spray with tube) and youll see an increase.
It's not about looking for the superior plug, it's avoiding the lousy ones! lol
well you do have some spark plugs on the market that cost 2 bucks a piece then others costing over 6 bucks a piece.... such as a E3. I have never noticed an increase in MPG changing the plugs unless they were so bad it was misfiring like crazy. I just changed the plugs in my DD Saturn SL2 with 156k miles on it. They were rusty, covered in oil, and the gaps weren't even close to being within spec. Fresh plugs and it feels like it runs the same and MPG is the same...31 MPG average.
My truck has 56k miles on it. It has also been tuned by someone who knows what they are doing and I also know enough and know what to look for. O2 trims are spot on and the truck runs well other than getting crap MPG. From what I have seen though, I get right at what other real world numbers show. A crew cab HD truck with a gas 6.0 and a 4L80E is not going to get great MPG no matter what you do. It's also not going to be a powerhouse for towing but will handle most anything you can throw at it. Hell, my 5.3 Buick Rainier would only manage 16-17 MPG on the highway. Again, spot on for what other real world numbers show. My 02 Avalanche I had would get 14-15 MPG.
Redrocket- let's take a look at tranmission rations. Looks like it's a day to night difference between a 4L80E and a 6L80E. The 6.2/6L80 have a serious advantage right out the gate. Just look at the first gear ratio of each. Im willing to bet a 6L80 transmission would help a 6.0 motor tremendously.
6L80E
4l80E
I still plan on doing E-Fans this winter at some point, and have been thinking about doing LT's and still leaning towards one of Cam Motions's drop-in cams. I think that would give it a nice boost in power and make it more enjoyable to tow with. I love driving the truck as it's really comfortable to ride in. Just needs some power! Lol.
I keep forgetting most 6.2 motors have the DOD deal. Therefore a 6.0 with 6L80E sounds like it's a winning combination.
