Built 6.0 N/A motor spark plug help
Old Oct 3, 2017 | 07:59 PM
Bulldogz71's Avatar
Default Built 6.0 N/A motor spark plug help
Hey guys, my car has a 6.0, with texas speed prc heads, texas speed pistons, crank, and a bullet brand cam, long tube headers.
Right now I have NGK TR6 plugs in it, I have a slight miss at around 2-3K rpms.
I don't know that it is plug related, car runs great at WOT, the slight miss just happens at cruising speeds.
I believe the TR6 is one heat range colder than stock. I would like to try the delco iridiums, but I think they only come in the stock heat range. Should I try the NGK TR55 iridiums, or would they be too hot for my motor? I'm just wanting to go to an iridium plug that will last a while, and I'm just not sure what heat range is best for the car.
Thanks guys.
Old Oct 3, 2017 | 08:14 PM
HCI2000SS's Avatar
Being that you're n/a and around 100-150 hp over stock the TR6 should be fine. Before I added nitrous I ran them on my HCI 6.0 and they worked great
Old Oct 3, 2017 | 08:46 PM
Bulldogz71's Avatar
Ok thanks, do you think the TR55 iridiums would be too hot? I'm not sure if they make the TR6 in a iridium or not.
Old Oct 3, 2017 | 09:05 PM
HCI2000SS's Avatar
To be completely honest with your setup I would stay with the TR6. Its definitely a safer bet in your case
Old Oct 3, 2017 | 09:14 PM
Bulldogz71's Avatar
Alright, I think I found the iridium version of the tr6.
https://www.summitracing.com/parts/ngk-3689
Old Oct 3, 2017 | 09:17 PM
HCI2000SS's Avatar
Good deal. Problem solved
Old Oct 3, 2017 | 09:19 PM
HCI2000SS's Avatar
Btw, what HCI are you running? LQ4 or LQ9?
Old Oct 3, 2017 | 09:25 PM
Bulldogz71's Avatar
LQ9. I know the heads are PRC, seen the brand on them, but don't know the specs. Cam is a bullet custom grind, but not sure of the specs, very lopey idle. I'm not sure what intake is on it I'd like to know, car was built when I got it.
Old Oct 3, 2017 | 09:26 PM
HCI2000SS's Avatar
Gotcha. Any dyno or track numbers?
Old Oct 3, 2017 | 09:36 PM
Bulldogz71's Avatar
The previous owner told me he ran 7.10's. Does that sound about right? It's just a fun street car for me, I haven't had it at the track.
Old Oct 4, 2017 | 11:04 AM
pantera_efi's Avatar
Default SPG and Coil Dwell
Hi Dogz, I would like to know your Spark Plug Gap ?
The miss-fire could be related to ignition, what is your coil dwell ?
What coils have you fitted ?
What is the AFR when the miss occurs ?
What is the condition of your SPW ?
Your could use an ARF meter, an EGO read out.
Lance
