4l60e to 4l70e interchangeability
No. You can't swap these two transmissions between those vehicles..
The '05 has an EXTERNAL neutral safety switch and your '11 has an INTERNAL switch.
Further, the '11 will have an ISS (input speed sensor), whereas your '05 does not use one. For these reasons, these two transmissions will not interchange with each other.
Also, are you sure your '11 actually has a 4 speed trans and not the 6 speed-such as the 6L80E??? If it has the 6 speed then NO WAY IN HADES will either of them interchange with each other.
