85mm Throttle Body
Old Nov 1, 2017 | 07:18 PM
BarnesGN's Avatar
Default 85mm Throttle Body
seen a 85 mm Throttlebody on eBay from Newpoint motors for about $90. Anybody try one? Is this too good to be true.Wanting to add some power to the ls1 car.
Old Nov 1, 2017 | 07:38 PM
Jtm2085's Avatar
I don't really see the point if you still have a 78mm opening on your intake
Old Nov 2, 2017 | 05:39 AM
BarnesGN's Avatar
Yes my 99 Z28 is stock with a lid, tune, and cat back exhaust. I would like to upgrade to a ls6 intake, are you saying that at my power level it would be a waste?
Saw these speed daddy 85 mm throttle bodies for around $90, are they any good?
Old Nov 2, 2017 | 07:59 AM
Jtm2085's Avatar
I'm saying going to a larger throttle body probably won't make a huge difference since the opening of your intake manifold will still be the same size. I would just port your stock throttle body until you step up to a larger intake (fast 92 or 102).
Old Nov 6, 2017 | 08:43 AM
MonmouthCtyLS7's Avatar
That's expensive, I picked up a 85mm truck Maf off Ebay for $40-50 bucks. Like mentioned above, it will be effective but only if the attached parts are upgraded as well,
Old Nov 6, 2017 | 08:48 AM
The Warr Ebay ones are good if money is tight, Being that everything else besides the lid is stock I would wait. LS6 opening is the same size, if you went that route I would just port your stock TB. That should give you a little kick in the pants or at least some improved throttle response.
