IAC valve click when key on but engine off
Old Nov 4, 2017 | 05:08 PM
TheNutDriver's Avatar
Default IAC valve click when key on but engine off
Any ideas why this is happening?
Old Nov 4, 2017 | 05:23 PM
JoeNova's Avatar
Restricted User
Does it do this forever, or just after key-on.
The IAC is forced to reset itself when the key is turned on. It bottoms out and resets is step count to get a true home position.
Old Nov 4, 2017 | 05:24 PM
Im not sure if it does it forever or not, as i only just noticed it tonight after turning the key on and having my head under the hood looking at something else. Whilst i was under there (5 minutes) it was doing it.
Old Nov 4, 2017 | 05:41 PM
I might add at this point, that the car is seemingly running just fine.
Old Nov 6, 2017 | 07:48 PM
00pooterSS's Avatar
Pretend you never heard it do it if it's not causing problems. It's probably hunting position/checking itself.
Or replace it. I'd forget about it.
