Aussie here LS1/ls2 questions
I got told the LS2 intake will fit but i need a 92mm throttle body (cable driven) and a LS2 fuel rail but i can reuse my ls1 injectors (2001+ model)
Can anyone else confirm? the ls2 intake i can get a hold of is "cheap" here at 350aud shipped
The LS1 injectors are longer and skinnier than the LS2. I think they make an adapter O ring that is fatter to adapt the LS1 injector to the LS2 manifold but I'm not 100% sure you'll have to look. Also if you try to use the LS1 rail on the intake you'll also have to do some modifying of the mounts for the different length etc.
You'll want to look for a 90mm throttle body. The LS2 throttle body is a 90
You'll need a throttle cable adapter bracket to run drive by cable on the LS2
You'll need injector wire harness conversion clips, the LS1 and LS2 have different connectors.
I'd look for a used fast 90 or 92 and then reuse your LS1 fuel rail and injectors and buy a throttle body. The cost may come out to around the same as having to buy new injectors and all the conversion pieces
The cost is $135.00 US
I do have "cores" for $100.00 US
I have a better price for the LS-2 intake ?
I have a Truck LS-2 90mm intake for even less ?
I ship a lot of coils (IGN-1A) into the Aussie market.
You could ask Green Brothers or Superior Rigging Service about my abilities.
My guess for a shipping cost is $75.00 USPS (manifold with bits)
Lance
That LS6 will work well with a cam and stock heads. So grab another one of those or shop for a used fast 90
