Need some advise
Old Nov 27, 2017 | 11:49 AM
ramirop's Avatar
Default Need some advise
im finally getting my camaro up and running after four years of being parked. Im replacing the rear main seal and engine cover seal. When I removed the cover and inspected the rear engine cover seal it looked dry and the gasket came off the aluminum. I had my rear seal and main in my tool box for four years in high temperatures, do I need to add a thin film of oil to the cover seal or should I just get a new set say either gm or fel pro.
Old Nov 27, 2017 | 12:53 PM
00pooterSS's Avatar
Yeah the old seals get dry and brittle and come off in pieces. The new seal should be fine. They sit in hot warehouses for long periods of time and shipping containers etc etc.
If you're truly concerned just buy another dealer plate and seal.
Definitely do the plate and seal and carefully install it making sure it is aligned properly or it will leak.
I put them on the crank and let the seal locate the plate. Then I lightly turn each screw in little by little pulling the plate in straight ahead and flat (turn each screw). Right before they all bottom out do a final check and make sure the plate can still move freely around on the bolts so it is still locating itself where it needs to be and isn't being pulled up or down, left or right by the bolts.
Go slow and easy during that part and you'll get the plate where it needs to be.
If you slap in on and hammer it down you are likely to pull it in one direction and the crank seal won't be centered on the crank. Or you can pull the new seal out and use a plate locating tool.
I've done several front and rear seal plates with the above method without the locating tool and have not had an issue.
Old Nov 27, 2017 | 02:50 PM
ramirop's Avatar
On the cover seal is it okay to just lubricatev with clean oil or does it go or should be installed dry. I ask because with my fingers I spread a lil drop of oil all around the rubber gasket. On the main seal I just put fresh oil on the o.d. Of the seal
Old Nov 27, 2017 | 05:55 PM
00pooterSS's Avatar
I install all seals dry unless they make contact with a moving part, like the crank seal itself. Or like an axle seal for example.
I can't see that it would hurt it, since it is made to seal oil, but I don't see a reason to oil it.
Old Nov 28, 2017 | 08:56 AM
ramirop's Avatar
Thanks bro for your input.
Old Nov 28, 2017 | 10:33 AM
00pooterSS's Avatar
