Vacuum Sound & Injector Ticking?
Old Jan 5, 2018 | 09:12 PM
Treyvs's Avatar
Default Vacuum Sound & Injector Ticking?
Hello,
I've done some looking on here and haven't found a post posing a similar question.
Upon startup, I hear this rather pronounced hissing/vacuum sound for about 30 seconds or so, then it stops with a dramatic winding down sound. After arriving at my destination about 45 miles away (highway speed), I stopped and noticed a slight ticking sound (concurrent with engine rpm). Investigation produced the absence of a PCV valve in the valvecover, but the ticking didn't sound like a lifter or rocker. (maybe injector?) Could the open valve cover produce such a sound? The car didn't make this sound when I purchased it and drove it 400+ miles home or on some of the other short drives around town. No codes were thrown nor was the vehicle any different to drive. Are LS1 top ends just that noisy?
I've worked on LS cars for quite some time, but this is my first ownership experience, so I want to know in which direction I should start investigating.
I can take a video if requested.
Thanks!
Old Jan 9, 2018 | 11:20 AM
gMAG's Avatar
When the hissing starts, is the sound steady, or does it vacillate? If the sound is not steady, it could be that your Idle Air motor/the plunger inside of it may not be able to find its’ proper setting. Can you make a video for us?
Old Jan 9, 2018 | 03:53 PM
Treyvs's Avatar
I was able to identify the vacuum sound as the air pump, which was not hooked up to the original system due to the H/C/I swap, so I pulled the fuse and that solved problem #1. I'm going to change over to a 5W-40 oil this weekend and see if the top end quiets down when at operating temp. I'll report back upon completion. I appreciate the insight!
Old Jan 10, 2018 | 05:25 PM
gMAG's Avatar
I went to a (heavier) racing oil for the same reason. With a hot engine, the noise is diminished. Pushrod size is correct.
Old Jan 13, 2018 | 10:34 AM
Treyvs's Avatar
The heavier oil seems to be doing the trick!
