What size injectors would i need?
Go with the 36's.
I ask the question why the 340 pump, when the 255 is MORE than adequate? I actually question if the stocker would have been plenty...
This injector will Idle BETTER that OEM 27's.
Your engine should make 550+ HP (640 x .8 is the requirement)
The truck intake (TBSS ?) should use the Long Injector.
MAX RPM is important for a correct specification ?
Does your harness use the Truck Injector Connector ?
Lance
