12 v to neg battery post from alt stud
Old Jan 21, 2018 | 10:40 PM
paulpme's Avatar
Default 12 v to neg battery post from alt stud
i get 12 v from alternator stud to neg battery post before hooking up negative cable
Old Jan 21, 2018 | 11:07 PM
Darth_V8r's Avatar
Moderator
Most of the alternators we see on this site, the post is 12V and ground is through the body
Old Jan 22, 2018 | 01:30 AM
big hammer's Avatar
Ya that’s what you should get
Old Jan 22, 2018 | 04:47 AM
HappySalesman's Avatar
assuming you have the positive terminal hooked up, that is absolutely normal. you're completing the circuit between the alt wire (which connects directly to the positive terminal) and the negative terminal. same as putting the leads on both battery terminals lol
