24x crank sensor bit pattern?
Old Mar 8, 2018 | 08:14 AM
Ryoko's Avatar
Question 24x crank sensor bit pattern?
Has anyone made any sense out of the 24x crank sensor bit pattern? In theory, the pattern can be used to identity which cylinder is on TDC. All I've been able to figure out for sure is that the falling edge of the pattern lands on 15 degree spacing which makes clock recovery easy enough. However, the rest of the pattern looks like gibberish. It looks like 3 bits per cylinder which makes sense. But beyond that is a mystery. Maybe I'm looking for more than what's there?
