Different duals.
Old Jul 4, 2004 | 06:01 PM
V8_DSM_V8again's Avatar
Default Different duals.
Magnaflow makes a dual inlet dual outlet muffler with "true-x" cores...
Basically a crossover pipe like perforated core...
This means that you could mount it horizontaly and have an inlet and outlet on each side of the muffler... Flow from the left dual goes in the front left inlet and out the rear right outlet to the right tailpipe. Flow from the right dual goes in the right front inlet and out the left rear outlet to the left tailpipe.
IMHO... could be a pretty stock looking system esp if you dont go for the polished ss... or hit the ss with a scuff pad on a buffer on the backside to flatten the finish out... Well the only dual 3" x flow is only in aluminized anyway.. #12599
So like this
With this inplace of the rear chambers. Also intlets and outlets are'nt criss crossed because the muffler core does that...
http://www.magnaflow.com/02product/u...s/5x11dd22.jpg
