black plastic line that runs into throttle body
Old Mar 19, 2018 | 07:42 AM
ben a's Avatar
Default black plastic line that runs into throttle body
I bought my first LS1 recently it is from an 04 gto and I don't know what the black plastic line is for that run the length of the engine on top drivers side into the throttle body. it has a green plastic cap at the back and some sort of quick connect fittings. thanks
Old Mar 19, 2018 | 07:58 AM
RB04Av's Avatar
That's the evap line, goes to some stuff near the gas tank eventually. Collects fuel vapors from the tank rather than venting them to the atmosphere.
Old Mar 19, 2018 | 08:14 AM
ben a's Avatar
well that makes sense it would have good vacuum. I will have to check my paper work and see if it was deleted from the pcm and just plug it off. thank you very much.
Old Mar 19, 2018 | 08:17 AM
RB04Av's Avatar
Right: it has vacuum SOME of the time, but not full-time. The black thing that plugs into the intake is the purge solenoid valve which should only be open on command from the ECM.
