Ported 853 heads
Old Mar 22, 2018 | 11:39 AM
locologan's Avatar
Default Ported 853 heads
I have some larry meaux ported 853 heads. I believe they have 2.06 intake valves amd eithrr 1.58 or .160 exhaust valves. I welded up the notch on the head so i can run normal mls head gaskets. What are your guys thoughts amd what do you think they flow
Old Mar 24, 2018 | 11:32 PM
wannafbody's Avatar
Check to make sure that intake valve clears a 3.9 bore
Old Oct 27, 2020 | 10:33 PM
RaceDevil's Avatar
The 317/243/799 Heads with the guide spacing and casting limitations will not go over 360cfm intake valve with 2.08" ... well unless they are welded on underside of the short turn and spring pocket
