Quick disconnects for AC condenser?
So. I am wondering if anybody has tried to put in quick disconnects in the two lines to make for easy removal of the AC condenser for installations such as this and maybe for a few pounds at the track. You could use connectors and/or valves such that all four 'ends' are closed after the disconnect happens. Would we need a bypass on the 'car side' of the system (to complete the circuit after the condenser is removed from the loop)? Of course if its just when working on the car, its not running anyway.
At the least I'm replacing some of this line with flexible line on the one side so this doesn't happen again.
If you are talking about the line that goes from the bottom right connector on the condensor to the compressor to the evaporator up top I just replaced mine last week. It has metals end and rubber in the middle to allow it flex. Mine rubbed a hole in the metal on the bottom from rubbing against the frame since I lowered the car 2 inches. It is a PITA to remove and replace. BTW if it is that pipe I have the part number as well if you need it.
I dont think anyone has put the disconnects in due to cost , it's alot cheaper just to run the stock pieces.Any one that is working on the car that much prolly doesn't have A/C on it anyway........
