Silverado missfire ALMOST solved PLEASE HELP
Second, I would install NEW Spark Plug Wires.
What you see is High Voltage current "leak" common with old wires/bad wires.
That current BELONGS inside the cylinder, good for HP/Fuel Mileage.
I fit FireCore Wires, call OR Call Rick@Firecore.
Your coils should be fine, check the A-Bit connector for "Frankenstein" marks.
Lance
I've been a tech for 20 years and 99% of the time that I have some crazy hair brained thing going on that just seems impossible it relates to something extremely simple.
Absolutely is NOT the pcm malufunctioning or an over voltage situation happening, that's not how any of this works. Plus I've never heard of one of those PCM's failing, so to answer you it is not common at all and in my time as a tech PCM's fail about 1 in 1 million, so anytime you ever think "it's probably the PCM" stop and look for something else because it's incredibly rare.
The issue could be that the voltage in the coils are shooting the path of least resistance due to a lack of grounding in the block. Or that the wires are really bad and the spark is seeking a different path.
The erratic behavior with your gauges also points toward ground or charging issues.
If you have those replacement style battery cable ends (where you cut the originals off and bolt them on), replace them, they're junk new and only get worse.
Check your body grounds closely as well from the battery to the body.
Check your voltage at the battery with the engine hot and after it's been running a while with headlights and everything turned on
