Coupler lid options for 102 SD to TB
Thanks for the help! Car is a 383 Ls1 block stroker guessing around 480rwhp.
Otherwise you can pretty much get a custom one from intakehoses . com as mentioned. I used them years ago for a 85 maf to 90 tb coupling, worked very well.
One thing I'd be aware of though - the straight silicon couplers are a bit stiff vs rubber. If your motor torques over a lot (say if you have stock motor mounts) it can crack the lid.
