Question about temperature readings on LS1 swap
Now that there is a gauge which actually shows real temperature readings it brings up a couple of questions.
For background information my car has an LS1 engine with factory ECU and uses the Flyin Miata aluminum radiator with dual electric fans and an aluminum plate to shroud the radiator flow thru the fans.
It appears to be a workable and well designed system.
The ECU is programmed to have both fans start at 190 degrees F.
Is this reasonable or should they be set to start turning at two different temperatures?
If so, what temperatures are recommended?
Last week while driving in stop and go traffic the temperature gauge climbed to 220 degrees F. with local weather conditions indicating low 80's. After getting home I found that one fan relay had failed so only one fan was working so I replaced that relay.
During normal driving on the highway the car runs right at 200 deg. F. or lower.
Is that temperature reading anything to worry about or should I wait and see what the temperature reading does when the weather conditions get over 100 degrees?
What temperature should be the maximum before pulling over and letting the car cool down if it happens again?
Thanks for any information or insight.
Bruce
__________________
Program the fan to come on at 200*, and off at 196-197*. I'v found that having a hysteresis <3 doesn't work well. If you could program it to have the fan off at speeds above about 50mph or so, that would be good, too. Again, Set your hysteresis above 3.
