wiring
Old May 8, 2018 | 05:26 PM
KevinReay's Avatar
Default wiring
I have swapped a 1998 LS1 into a 2002 V6 car swapped the harness from the 98 into the 2002. now when I hook up the battery the starter turns with out the key on. is there a wiring diagram of what pins to move or do I have to change the steering column harness.
Old May 8, 2018 | 09:32 PM
B52bombardier1's Avatar
Somehow, you have connected full time 12 volt power to the starter solenoid. Backtrack that wire to its end and see where it is connected. This wire should be key switched on at the start position of the ignition switch . . . not full time 12 volt power on.
Rick
